Good place to buy ISF Ecu??
Old 05-22-15 | 11:46 AM
Tro209's Avatar
Tro209
Default Good place to buy ISF Ecu??
Hey everyone, just wondering if any of you who have the ISF steering ecu could recommend a place for me to purchase one for myself. I plan to put it on my 06 Is350.
Also does it have to be a specific Ecu or does any year ISF Ecu work? Thanks everyone, I look forward to your replies.
Old 05-22-15 | 04:27 PM
getafewliv's Avatar
getafewliv
There's differences between the different years for ISF ECUs. I got the 2012 ISF ECU from my dealer locally. They were actually cheaper than if I bought it from the US (I am in Canada).
I believe the 2013 ECU was more expensive and the differences were not well known.
I say, call your local dealer and ask how much for the 2012 ECU, then try and get them to come down a bit on price. I think I paid $300.
Old 05-22-15 | 06:01 PM
lexus316's Avatar
lexus316
Whats the advantage of the isf steering ecu in a is350?
Old 05-22-15 | 06:45 PM
jgoorn's Avatar
jgoorn
A more direct drive a BMW drag your hand on the road steering. I am coming from an RX300 and I am trying to avoid doing this because the IS already drives so much better.
Old 05-23-15 | 05:56 PM
Tro209's Avatar
Tro209
So is the dealer my only option for buying the ecu?
And would buying a 2008 isf ecu still have the same effect as a 2011+?
Old 05-23-15 | 06:29 PM
redspencer's Avatar
redspencer
OG Member
The 08 IS-F steering ECU will give you a heavier steering feel but the feedback will be lacking compared to the 11+ IS-F steering ECU. There's a lot of great information on the differences between the 08-10 and 11+ IS-F steering ECUs on this older thread:
https://www.clublexus.com/forums/is-...it-2010-f.html
It's unknown what improvements (if any) are found with the 13-14 version in order to justify the additional $200 dollars over the 11-12 version.
Old 05-23-15 | 06:43 PM
Tro209's Avatar
Tro209
Perfect! Just the info I was looking for
Thanks for your Input
Old 05-23-15 | 08:37 PM
andper10's Avatar
andper10
The cheapest place I could find the '11+ ISF steering ECU (89650-53041) was MyLParts.com, which is run by a California Lexus dealership. It came out to about $470 after the 10% off ClubLexus discount code "CL5". TLS Auto Recycling has a used one from an '08+ (89650-53041) listed on http://www.ebay.com/itm/08-09-10-LEXUS-IS-F-POWER-STEERING-COMPUTER-89650-53040-/371172366754?hash=item566b98d9a2&vxp=mtrfor $300 currently, but I would go with the '11+ model if you are going to bother with it.
That and F-Sport sway bars were the two best upgrades I have purchased for my IS350.
Also you will probably want to run in PWR mode most/all of the time after the upgrade to activate the much less intrusive sport mode traction / VSC control and stiffer steering. I found that PWR + S is more comfortable than PWR + D for normal driving because it avoids the aggressive downshifting while still retaining the sport mode benefits I mentioned.
Old 05-24-15 | 12:51 PM
nosurprise's Avatar
nosurprise
How do you drive in PWR+S? Just select the highest gear as limit?
Has anyone driven the 2014 3IS and see how the steering compare? The 3IS steering definitely improved when I drove it and I wonder it's similar to the ISF steering upgrade. I'm considering doing this upgrade ...
Old 05-24-15 | 10:05 PM
Tro209's Avatar
Tro209
The cheapest place I could find the '11+ ISF steering ECU (89650-53041) was MyLParts.com, which is run by a California Lexus dealership. It came out to about $470 after the 10% off ClubLexus discount code "CL5". TLS Auto Recycling has a used one from an '08+ (89650-53041) listed on Ebay for $300 currently, but I would go with the '11+ model if you are going to bother with it.
Thanks, sway bars are definitely on my to do list. Also seeing as how I have an 06 is350, couldn't I just do the pedal dance to deactivate traction and vdm?
Old 05-26-15 | 04:40 PM
Tro209's Avatar
Tro209
Can anybody help?
Old 05-26-15 | 04:53 PM
redspencer's Avatar
redspencer
OG Member
Can anybody help?
Yes, doing the pedal dance on the 06 model will disable traction control and VSC.
Old 03-19-24 | 11:31 PM
HillChang's Avatar
HillChang
2nd gear
[QUOTE=Tro209;9050518]那麼經銷商是我購買ECU的唯一選擇嗎?
購買 2008 isf ecu 是否仍具有與 2011+ 相同的效果?[/QUOTE
]Hello, I am also looking for ISF late-stage steering machine computer 89650-53042. Can you tell me how to buy it, a store or a second-hand good product?
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAAngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2dwmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAnwbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFYl8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6dyISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
josephx66
06-19-18 08:56 AM
skottydznt
09-22-16 03:19 PM
MRxSLAYx
IS F (2008-2014)
49
09-17-14 08:26 PM
Nigel-JDMParts
IS F (2008-2014)
262
05-24-14 03:53 PM
