DRL lights not working
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Hello there,
So a few days ago I've purchased a set of LED DRL's light for my 2010 Lexus IS350 and proceed to install them.
After I've installed the LED DRL's they won't turn on at all, so I've tried putting the old bulbs back and those won't turn on either.
A friend of mine told that i might blew up a fuse in the car. Now, I am trying to find the DRL light fuse in the engine fuse box, Driver side fuse box and passenger side fuse box but i cannot find it. I've looked in the owner's manual and it has all the description for all the fuses in the car except the one for DRL lights, it might be that is not named DRL lights fuse or something like that. So i was hoping that someone would know which fuse im suposse to look for.
Please help
Please help
The same thing happened to me when I installed the Decoder and LED DRL. The fuse is in the driver's side fuse box. It is on the second set/group of fuses underneath so you will have to remove the small section of the fuse box on top. I will try to snap a pic if you can't figure it out.
Btw, the good news is that the fuse hasn't blown again since then.
pheonix72,
I believe you have a different Fuse Box because I couldn't find that fuse anywhere in my car.
Is that a picture of the fuse box that's under the hood of your car?
Thanks
Thanks
