Axle nut torque spec???
couldnt find it either but im sure its over 200 lb ft. or if you marked where the nut was located on the thread, then just tighten to same spot.
also, when you removed your axle nut, did you take it off car jacked up? or with wheel on ground? im looking to change out my rear knuckle on is350 this week.
thanks,
thanks,
vd2021 (04-03-21)
