I've got 19" staggered setup and just wondering what is the best psi to set. Is it the same as stock 18's or is it different? Thanks in advance for the help.
50 psi is the max psi for the tire. On your car, it depends on your set up. Stretch/no stretch, mad tyte camber/factory specs will determine what kind of psi you should use.
Go with your OEM tire pressure specs. It does not matter what size tires you use.
So stagger setup is 35 front / 37 psi rear.
You can go 1-3 psi higher though
As you drive in a longer duration or in hot weather climate. The tire pressure will increase. So you would not want it to be on Max Psi. Hope this helps.
