Need help please!!!!! [Very little sound from rear speakers]
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Hey guys,
I've been on the forum ever since buying my 2006 is350 and trying to fix the issue I have having my searching on the forum. However I have not been able to find any answers
The problem I am having is that the sound is only coming from the front speakers and the rear speakers practically have no sound. I am unsure if it is a problem with my amp. I have the ml setup, and there is no bass, or rear sound.
Would anyone be able to help out with some much needed advice
Thanks guys
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Thanks guys
So I've looked at the fade settings and when I play the sound through the most rear setting (like only the rear speakers) the sound is so small you can hardly hear it. I'm not sure if it is normal because I looked up the size of the speakers for the rear doors and they were quite small. I'm currently trying to find out a way that I can hopefully change out the ml speakers for some aftermarket ones and then put some extra juice through them.... also thinking about wrapping my dashboard in suede
mcamson
12
09-04-11 12:30 AM
