speakers issue in the "is 250 2007"
Hi All,
I have a weird issue with my Head unit (not multimedia),
when the engine is off and the switch is on the system works fine but after I turn the engine on the system resets and the speakers stop working as if the speakers were muted.
please advice
please advice
I've had this issue before, it is intermittent and doesn't happen that often. I usually unplug the amp in the trunk, start the car, let it run a few mins, the shut it off and plug the amp back in. Not sure if that's what your supposed to do, or even it is good for it, but it seems to make it work for a few months trouble free...
Speaking from "aftermarket" install perspective (bare with me here there is a point) listening with the engine off powers the amps and then dumping the power to start the engine in aftermarket systems will often cause a "pop" as the amp powers off and then is brought back to life quickly. It's to do with the capacitors in the power supply not fully discharging so the output devices are still partially "alive" when power is restored, this causes a spike to be created in the audio output stage.
A number of manufacturers of OEM kit tend to have a mute circuit that will protect speakers from this potentially damaging problem.
My suspicion would be that if you listened with the ignition on but engine off, then pulled the key - all off, waited 10 seconds and then started the engine the system would work as intended.
Now if this were a bit of software i'd say it'd be a bug!
OT: My 07 also has this issue, perhaps it's not a coincidence..?
mhsu408
01-08-06 12:47 PM
SimplyZBes
01-07-06 09:39 PM
Blue98Gs3
03-31-04 04:31 PM
PERRYinLA
02-05-02 07:09 AM
