Couldn't rev past 4500rpm
Old 07-15-15, 09:11 AM
Nixcision
Nixcision's Avatar
Question Couldn't rev past 4500rpm
Last night, in neutral, the car wouldn't rev past 4500 rpm.... it would just get to that in the rev range, and drop down with no throttle response.
Similarly, in park, it did the same thing.
I turned the car off, and back on again, and this seemed to resolve the problem.
I have a 2009 is250 awd with about 83000km on it... regular scheduled maintenance was for 82k, but I haven't gotten the chance to take it in yet.
Lately, I have been noticing some interesting things... also including when shifting from drive to neutral and back to drive, there is a couple of seconds of delay with throttle response once back in drive.
Any ideas on what this could be? MAF or throttle body related? I'm hoping its nothing transmission related
Thanks
Old 07-15-15, 11:40 AM
getafewliv
getafewliv's Avatar
It's the car telling you that you have no reason it rev it that high in neutral or park. Your car is fine.
Quit revving it high when it's not in gear.
Old 07-15-15, 12:45 PM
Gville350
Gville350's Avatar
Someone has worn out their converter.
Old 07-15-15, 01:02 PM
Nixcision
Nixcision's Avatar
So in all seriousness, is my car actually being preventative by preventing me from revving or do I actually have a transmission issue as Gville350 mentioned?
Old 07-15-15, 01:11 PM
Gville350
Gville350's Avatar
You should not be limited to reving, whether at a running stop or running in any gear.
Old 07-15-15, 01:14 PM
Nixcision
Nixcision's Avatar
Which I agree with, but the fact is it happened, I switched the car off, and it was "resolved"... I'm concerned because transmission repairs tend to be a PITA and take a lot of labour hours....
But at the same time, I'd like to know if there's actually a problem with the car or if it was a one-off problem. I'll try and see if I can get a reader to see if she's throwing any codes...
Old 07-15-15, 01:24 PM
Gville350
Gville350's Avatar
Have you seen the CEL recently? The ECU does store codes, but they have to be triggered first to be stored.
You're best bet is to wait it out and see if the problem continues to reoccur.
Good luck!
Old 07-15-15, 01:33 PM
Nixcision
Nixcision's Avatar
Nope no lights at all on my dash! You have scared me now with the idea that my torque converter may be worn .... I'll keep an eye out.
Old 07-15-15, 01:44 PM
getafewliv
getafewliv's Avatar
I will check my car later, but I am fairly certain the ECU limits the RPMs in neutral or park because it's not good for an engine to rev high when there's no load.
But regardless, if the car shifts and acts fine when you just drive it properly and leave it in gear, then I wouldn't worry about it.
Old 07-16-15, 12:02 AM
Nixcision
Nixcision's Avatar
Makes sense, but I've revved high before in neutral and park (to make noise) and it hadn't happened.
Old 07-16-15, 07:50 PM
EZwider
EZwider's Avatar
This happens to me randomly sometimes. Usually I can redline and it spits fast. But sometimes for some reason it doesnt let me rev past 4500 like you're saying. Random, I never heard anyone with the same situation.
Old 07-16-15, 11:33 PM
Nixcision
Nixcision's Avatar
Yeah its weird and hard to explain if you haven't experienced it... because its so unusual!
Hawkeye921
06-25-19 04:53 PM
Bambam40
04-02-18 12:49 AM
wakebord99
04-14-17 10:02 AM
Franco240
01-29-12 12:22 PM
1seeker1
ES - 5th Gen (2007-2012)
02-03-07 02:20 PM
Quick Reply: Couldn't rev past 4500rpm
