Help/Advice Needed!! Uneven rotor wear!!
Old 07-17-15, 06:54 PM
RVCAis250
RVCAis250's Avatar
Default Help/Advice Needed!! Uneven rotor wear!!
Don't mind the huge spacers...
But seriously, I'm freaking out, what's wrong with my brakes? This doesn't seem like normal wear.
Old 07-17-15, 08:05 PM
jonathanz
jonathanz's Avatar
pictures of your pads and when installed please
Old 07-17-15, 10:06 PM
20LS01
20LS01's Avatar
Here are several causes:
- Manufacturer defect on the pads
- Installer did not apply the correct grease in the correct locations in the correct amounts (pad movement is crucial for a properly working brake system)
- the pistons were unevenly pressed in to make room for the new pads.
Old 07-18-15, 12:51 AM
LucianoLee
LucianoLee's Avatar
Rear brakes? It looks normal to me. Our car's rear brake pads don't go all the way on the rotors surface. Take a look at the old oem rotors, you'll see the same thing.
Old 07-20-15, 02:15 PM
Gville350
Gville350's Avatar
Yep, that's what they'll look like on the rears. Have the same deal going on with my Power Slot slotted rotors; the inner-most part doesn't even get touched by the brake pads. Now, do you have irregular rear brake pad wear?
sf3r8z
ES - 5th Gen (2007-2012)
04-09-14 02:39 PM
btle29
GX - 1st Gen (2003-2009)
08-28-08 05:59 AM
TJW98LS
04-10-07 09:21 AM
DarKnight
Suspension and Brakes
10-02-06 05:28 AM
rx300mm
RX - 1st Gen (1999-2003)
02-26-05 08:10 PM
Quick Reply: Help/Advice Needed!! Uneven rotor wear!!
