06 IS350 -- No bluetooth audio
Looking for a workaround to get bluetooth audio going without replacing the whole nav system with a new one. Anyone use the BT adaptor that plugs into the aux port? Any other ideas?
This will work:
https://www.clublexus.com/forums/is-...sing-a2dp.html
If you have an Iphone this will work too
Like WORKD250 said this will work! Exact setup I'm running. Pairs up well with my Samsung Galaxy S6 Edge. I also bought a ground loop noise isolator. I was getting a lil hissing sound and this took care of it. Not very expensive.
Most Bluetooth and USB kit will do the job. As for hissing sound, you should hard wire the ground to good grounding point I state of using stock ground. I grounded mine to 2 grounding point and no hissing sound at all
I use the same ground loop isolator as roboeclips, needed if you get static/whining noise from the engine. (There was a TSIB from Lexus to install a similar device (out of sight) at no charge, but all the cars it was applicable to are now out of warranty)
If you have a Samsung Galaxy or other phone that supports the aptX codec, I'd recommend buying one of the Bluetooth adapters that also supports it, as you'll get higher quality sound. I use this one:
my setup
same car as yours, this is the setup I use with my iphone, works perfect, takes phone calls nice as well, I keep everything in the console and plug into that aux port
looks like I use the same isolator as the other guys, works perfect:
If you have a Samsung Galaxy or other phone that supports the aptX codec, I'd recommend buying one of the Bluetooth adapters that also supports it, as you'll get higher quality sound. I use this one: Amazon.com: Kinivo BTC450 Bluetooth Hands-Free Car Kit for Cars with Aux Input Jack (3.5 mm) - supports aptX: Cell Phones & Accessories
https://www.clublexus.com/forums/att...noise-tsib.pdf
