Daytime Running Light Suggestions?
Old 08-04-15 | 12:34 PM
dhuynh15's Avatar
dhuynh15
I just converted my DRL halogens to LEDs.
Note: This will disable your brights.
What you will need:
Decoders:~$10
Amazon.com: CUTEQUEEN TRADING 2PCS ceramics Connector Vehicles Auto Car 9005 or 9006 TO 9005 LED Bulbs on Fog Lights or Daytime Running Lights Error Free Load Resistor Decoder Wire (pack of 2): Automotive Amazon.com: CUTEQUEEN TRADING 2PCS ceramics Connector Vehicles Auto Car 9005 or 9006 TO 9005 LED Bulbs on Fog Lights or Daytime Running Lights Error Free Load Resistor Decoder Wire (pack of 2): Automotive
LED Bulbs ~$5
http://www.ebay.com/itm/371335314518?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
While you're at it, I'd highly recommend replacing your city lights ~$5
http://www.ebay.com/itm/291495787131?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The city lights make a pretty drastic difference.
Anyways, these are plug and play. I mounted the decoders using zip ties to the frame. If the city lights aren't working, reverse the polarity.
Old 08-04-15 | 02:01 PM
Joelseff's Avatar
Joelseff
What you will need:
Decoders:~$10
LED Bulbs ~$5
2pcs 9005 HB3 9145 White 6000K Daytime Running Light Bulbs for Toyota | eBay
Agq X2 White T10 168 920 921 5LED Super Bright 5 Smdled Parking Light BULBST644 | eBay
I have the LED DRLs in mine for over a year now with no problems. High beams still work..sort of. The light aims upwards a little enough to flash and even see better on dark roads, just not as good as OEM.
Question about the city lights, do they need decoders too?
Old 08-04-15 | 03:09 PM
dhuynh15's Avatar
dhuynh15
No decoders for the city lights. It is a very simple plug and play.
Old 08-04-15 | 09:00 PM
PAVGR's Avatar
PAVGR
Hey guys I m interested in these Led DRLs too.I just have to buy these bulbs and it's plug and play?I have the AFS.Does the high beams still work or not at all?
Old 08-05-15 | 11:46 AM
AlexiaMom's Avatar
AlexiaMom
What you will need:
Decoders:~$10
LED Bulbs ~$5
Nice I actually did already replace my city lights lol
sorry don't have a better pic right now I'm at work
Old 08-05-15 | 04:49 PM
dcguy's Avatar
dcguy
Definitely need the decoders if you plug in the 9005 led cluster bare they will flicker like crazy. Decoder is essentially a capacitor and an inductor coil to store a charge and clean the power to it. Decoders ive delt with have been extremely bulky and impossible to stash in the headlight behind the gasket cover without spitting the decoder case and taping the bageez out of it. Granted when you do go into high beam they get slightly brighter but you generally lose your brights. Still have the projectors tilt up and give you some but still... IMO I prefer the white leds and no highbeams over yellow/gold runners. Getting the drls disabled at the dealership is tough, some are cool, some say its a safety issue and they are not allowed to do it. You could run an hid but you would need a relay that is sensitive to 6v to power on a dedicated fused 12v source, drill and seal the back cover to run wires and mount your ballast.....yeah, PITA but can be done!
Old 08-05-15 | 08:53 PM
nosurprise's Avatar
nosurprise
What light are you guys talking about? Last time I check the city lights are on a pole
Old 08-05-15 | 10:45 PM
SeanIS350's Avatar
SeanIS350
Best upgrade for the DRL are 2011-2013 headlights... I know it's expensive, but if you are picky about the DRLs and can afford it, I think you will eventually end up getting a set.
I went through 3 different LED bulb set ups including that kit that VLedz used to sell... But was never happy with any of them. So just bit the bullet and bought the 2012 headlights even though I swore I would never spend that much for lighting. Anyhow... My search was over... And I have no regrets.
Old 08-06-15 | 11:48 AM
PAVGR's Avatar
PAVGR
I would too but I have the AFS and the new headlights doesn't so....
Old 08-06-15 | 12:25 PM
AlexiaMom's Avatar
AlexiaMom
These are the lights I prefer but just not in my budget right now
Old 08-07-15 | 04:49 PM
dcguy's Avatar
dcguy
Its the secondary small bulb that sits in the higher part of the reflector in the highbeam, some call them courtesy lights as well. Can be replaced with a 168 style led
tonysgs300
12-29-10 11:58 PM
kitphat
04-20-10 12:36 PM
skiz88
12-30-09 06:24 PM
conclevage
Lighting
10-18-06 09:12 AM
conclevage
10-17-06 11:22 AM
Quick Reply: Daytime Running Light Suggestions?
