So i just bought a megan rear camber kit and just wondering if i still need to buy toe arms to make it to 0. I dont want to go spend $100 on an alignment and then they tell me to get a toe arm and have another alignment. Thanks!
Unless you're looking for crazy fitment and lowering a ton, you don't need toe arms. I have FIGS mega arms for my rear's camber, and have been able to set camber close to factory specs and toe close to zero.
Stock toe is adjustable on all 2is's front and back. Camber is only adjustable stock on the front of AWD 2is's.
Thanks! Going to dial them in and send them to a shop!
Would the wheel fit properly if you zero the toe? My car tucks the wheel similar to yours. If I get a camber kit and straighten my toe and camber out I would probably be rubbing a lot.
