headlights question
headlights question
I have a 2007 is250 and wanted to change the headlights to the 2008 model which has the l.e.d strip. Is this plug and play or do I have to make changes or buy something else? Any input is appreciated.
Led headlight are from 2011-2013 depends what u buy if is loaded headlights then all u need is either repin the wire or run a wire to the fuse box to get power for the led and remove the fuse for the afs but u will lose ur afs function looks like u have hid. But if is a stripped version u need to transfer the ballast , all ur bulbs and ur low beam dust cover to the new headlight and also u need to buy 2 led module and 2 high beam back cover.
jtrinh
11-06-16 09:06 PM
derekw
09-02-13 03:09 AM
