Invidia Midpipe Fit?
Hey everyone, just wondering, if I purchase the invidia midpipe would it fit with any exhaust?
I currently have the Tsudo Axel back and I was wondering if this would even work out. Sorry if the question seems kinda dumb but I'm not the best when it comes to exhaust systems. Thanks
Should work fine. Axle back exhausts are made to work with the factory mid-pipe and the Invidia is the same in regards to fitment of the OE that you are replacing. Members have used the Invidia mid-pipes with lots of different axle back exhausts......
Interesting.... do you think if I take it to an exhaust shop they will be able to make it fit? I just wanna be 100% sure this will work before I throw away $300 lol
An exhaust workshop should be able to make it fit no problem. Lol my exhaust is pretty much built from scratch. If anything they should be able to weld the two together
I'm a bit confused as to where exactly the mid pipe goes, and I'm wondering if it's essentially the same thing as having my resonator deleted that I have now...??
Basically, are resonator deletes and mid pipe the same thing? Or am I just misunderstanding something?
Hey since you seem to know about exhaust pretty well, does a mid pipe increase the sound the exhaust produces?
I would advise against deleting the resonator. You drive a Lexus, not a Honda.
But I wouldn't say my car sounds like Honda though... ewwwww.
I will however more than likely put the resonator back on once I have my Invidia installed. Assuming I go through with it anwyay
Thanks for your suggestion but I think I'll keep my setup how it is for now. I like the resonator delete because it's more noticeable that way. From what I heard on a clip of a Tsudo with the resonator still on , it seemed way to quiet for my liking.
You should do the Invidia install. Their mid pipe has a resonator, so you don't get the "drone" and the mid pipe deletes the secondary cats which adds HP. You will be glad you did, trust me. Very few members have added the mid pipes and had O2 sensor issues (I didn't either) but there are spacers available in the event that you do. It is worth it!
Also when you say very few have had problems with the O2 sensors what exactly do you mean? Does it cause a check engine light?
your confusing yourself. Look at the mid pipe picture. It has 2 pipes connected to the main Cat down and 1 longer pipe to the Resonator which is connected to your Axle back. Keeping or Removing your resonator does not matter because the invidia mid pipe will replace all your oem mid section pipe including your old deleted / none deleted resonator. The invidia comes with a Resonator, but with no secondary cat that comes in stock mid pipes.
