Car not turning on after pumping gas
Hey guys just trying to see what's wrong with my car.. every time I pump gas it does not what to turn on I have to press de Gas pedal a couple of times so it can turn on.. help!!
Not sure if it applies, but perhaps check that your EVAP purge solenoid is not stuck open. If it is stuck in the open position, it can flood your engine after you've filled gas. Pressing the gas pedal down and trying to start the car puts most fuel injected cars into a "clear flood" mode that limits fuel delivery until the car starts.
Again, not sure if it applies, but it's a cheap part that can be changed pretty easily if that's what it is.
Good luck!
Good luck!
propertymo
06-03-17 12:49 PM
