Check VSC/engine/traction lights after ELF recall
That's a good idea. I also still have the old oil from my change prior to the recall. I could send both samples down for analysis.
So after some more probing via email the SA is saying that the O2 sensor monitors and reports back to the engine in terms of how much gas to use. He still thinks it's a defective O2 sensor that may be causing it to potentially put too much gas into the engine.
While this explanation makes more sense than what he said before, I still think that after doing the recall the engine just wasn't use to the amount of fuel it initially got and if it is relying until all the way until the fumes hit the O2 sensor to figure this out, my engine could already have been flooded by that point.
Either way, the car seems to be driving good now. So I think once I change the oil the light won't come back on. Plan on changing it this weekend. Will update this thread if anything else comes up.
I hve problem with my is300 , check vsc was coming out for are second during I start my engine but sometime its not coming out , I allredy bring the car to lexus dealer for checking this problem but but after the check they say no problem with the car, can someone help me with this
P Rock
01-13-16 09:54 AM
jhp9mm
27
02-28-14 01:27 PM
jennbrad
06-11-08 02:02 PM
