Loud Engine?
Do the IS250 engines tend to get super loud at around 40 mph? Today when I hit the interstate, after reaching 40 mph the engine started to roar like it was at high revs, but it was only around 2-3k rpms. Is this normal? Other than that, just cruising around on the streets the car is relatively quiet.
when the exhaust gasket blew out From the manifold to the y cat collector. I noticed the whole truck gets hot now. Like the heaters on all the time. And under the hood is cooking. So I’m sure at idle it could cause overheating. You most likely have something else going on also.
shlounek
Performance & Maintenance
03-26-04 04:51 PM
