Am I doing this correctly? [Headlight wiring]
This is a pair of 2012 headlights from Sewell Lexus.
Basically, I want the LEDs to be on whenever the car is on with 100% brightness all the time.
So here's what I think on how to do it. Please correct me if I'm wrong:
1. Pull out the 100% power LED wire (green I think) from driver's side headlight housing.
2. Pull out the 100% power LED wire from the passenger's side headlight housing.
3. Connect them together with a wire.
4. Connect another wire from IG2 or ACC fuse to the wire in step 3.
5. Connect the headlight connector from the car to the actual headlights.
6.?
7. Ta-Da
Please let me know if I'm doing it wrong! Thanks in advance!
6.?
7. Ta-Da
The red is ground and black is LED at 50% I believe. Also I think the ground has already been taken care of as Sewell wired them for plug and play. Thus I think the only part I'd have to do is change its power source to an IG2 or ACC fuse. But I could be wrong, of course
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
