2007 IS 250 Won't Start.
Old 09-23-15, 09:58 AM
xriddle
xriddle's Avatar
Default Updated Solved: 2007 IS 250 Won't Start.
SOLVED see below.
Hi guys ...
A couple times last week, first thing in the morning, when pressing my brake pedal my start button would not turn green hence i could not start the car. After locking and unlocking the doors a few times with the remote, which works fine, and fiddling around the car started. I drove to work, drove back home the issue seemed to be gone. Then a few days later same thing. Fiddle Fiddle and then it worked. I did notice once while driving that my security light started flashing while i was driving. Not sure if its related but something tells me it is. This Monday morning after not using the car all weekend the car wont start at all. Tried to fiddle with no luck. I tried both my keys ... I tried unplugging the battery, i tried holding the key up to the start button with the L logo touching .... all unsuccessful. My lights work ... the sideview mirrors lights come on when im close by ... my brake lights work fine. I can not turn on the radio or cycle through the ignition modes at all. I tried jumping the car but that doesnt work either. I found some threads about checking some fuses and all my fuses seem fine and don't test open. I've read it could be a bad ground ... Where could i begin testing for that? I also found a service bulletin about replacing the start button.
https://www.clublexus.com/forums/att...sb-0161-08.pdf
I think this is my only option at this point. Any insight would really be appreciated.
Update: So after building a techstream system and pulling the trouble codes I followed the troubleshooting instructions provided by alldatadiy.com (found a promo code 10$ for 2 years) on testing for the code and it concluded that I should swap out the Power Source ECU. Found one on eBay for 14.99$ swapped it last night and now my car starts. Thanks to all that helped. Saved thousands as the part alone is 800usd.
Old 09-23-15, 03:09 PM
getafewliv
getafewliv's Avatar
Hmm... weird. You have already tried everything I was going to suggest. Hopefully someone else has some useful info.
Old 09-23-15, 03:24 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
how old is your battery????
Old 09-23-15, 03:30 PM
xriddle
xriddle's Avatar
Battery is original but wouldn't trying to jump it omit that as the issue. Regardless I picked up a new one and will try to swap it shortly.
Old 09-23-15, 04:29 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
Change your remote battery too
Old 09-23-15, 05:59 PM
xriddle
xriddle's Avatar
Changed battery and remote batteries. No luck.
Old 09-24-15, 12:07 PM
xriddle
xriddle's Avatar
Bump ... I will recheck all fuses tonight. Just to make sure.
Old 09-24-15, 01:58 PM
IamLexus
IamLexus's Avatar
https://www.clublexus.com/forums/is-...ar-help-3.html
This person had a corroded ground problem, maybe your is the same?
Old 09-24-15, 03:11 PM
xriddle
xriddle's Avatar
Checked all the fuses for continuity and all are fine ...I checked both fuse boxes under the hood and both on the inside. How would I go about checking a chassis ground? Is there a service bulletin doc around for this anywhere? Thanks for all the replies.
Old 09-25-15, 06:19 PM
srt1
srt1's Avatar
should be from the fuse block to the chassis so inspect the cable.
Old 09-26-15, 07:34 AM
xriddle
xriddle's Avatar
Any fuse block in particular or both under the hood?
Old 09-27-15, 04:57 PM
xriddle
xriddle's Avatar
grounds all seem to be fine. re-check all fuses ...
Could the fact that I saw the security light flashing a few days before this issue started have anything to do with the root cause i'm looking for?
thanks again
Old 10-13-15, 05:12 PM
xriddle
xriddle's Avatar
An update: I changed the start button ... that didn't help. I bought a techstream cable on amazon and was able to pull some trouble codes.
Trouble Codes:
B2287
B2289
and found this in relation
http://goo.gl/MJR307
Can some help me located the ECUs in question?
Power source control ECU
Transponder key ECU
Thanks
Old 11-05-15, 03:25 PM
xriddle
xriddle's Avatar
Trouble Codes:
B2287
B2289
Transponder key ECU
Thanks
Solved. See first post for details.
Old 11-06-15, 12:26 PM
Gville350
Gville350's Avatar
So the key fob transmitter ecu went bad and that's what you had replaced? First I've read about one of those going out.
Quick Reply: 2007 IS 250 Won't Start.
