How do i turn off airbag
Old 09-27-15, 06:47 PM
Smitslex
Smitslex's Avatar
Default How do i turn off airbag
Long story short, airbag light came on the dealer put a whole new harness in that cost 3500 which after they installed did not turn of the airbag, they said it went off for a second then came back on now they said a need a passengside airbag seat ecu. When will it ever end? Well i never went back, Is there way i can connect something or do a zero point calibration to turn off the airbag? i seriously think the dealer is trying to rip me off i won't go back. i spend 1000 dollars for a rear axle and they belt the backing plate and it made noise after i got it back, they literally suck at customer service i called lexus corp 3 times and got credit but anyway what could i do to turn the airbag light off?
Old 09-27-15, 10:07 PM
skullkandy
skullkandy's Avatar
should get that sh#t checked...
..but if you want the light gone, take your cluster off then proceed to take the T10 bulb for the airbag light out =/
Old 09-28-15, 09:51 AM
Smitslex
Smitslex's Avatar
That's what i said is i had it at the dealer they should have checked all that, they said the passenger side ecu airbag harness is bad which i think is a crock of ****. I think they unhooked something to turn it off. I swear i don't trust them with eyes on the back of my head.
Old 09-28-15, 02:25 PM
mandyfig
mandyfig's Avatar
Airbag is a safety feature, you need it to work when you need it. Please get it fixed.
Old 10-01-15, 06:31 AM
kolyan
kolyan's Avatar
In most cars if bulb is out, it beeps to let you know its out
Old 10-01-15, 07:15 AM
Bichon
Super Moderator
Bichon's Avatar
I suspect it's an LED, not a bulb anyway.
Old 10-02-15, 06:00 PM
Icy350
Icy350's Avatar
Had the same issue, Contacted my local mechanic since the dealership wanted 2gs, he soldered some wires for me and its been good. Cost me like 90$.
Old 10-02-15, 07:56 PM
srt1
srt1's Avatar
im not a fan of airbags but if it works properly then cool. Sorry I can't help out
Old 10-03-15, 07:23 PM
whitebeast
whitebeast's Avatar
FYI, most of new car use LED instead of T10 build (old school). Lexus is using LED
Old 10-03-15, 10:06 PM
freeuser
freeuser's Avatar
try this it fixed my airbag light hope it helps
https://www.clublexus.com/forums/is-...ion-tsb-5.html
UCrazyKid
IS F (2008-2014)
18
03-19-19 02:25 PM
Babak
11-03-17 02:02 PM
Smitslex
05-05-15 07:31 PM
little2576
03-28-15 06:51 AM
Smitslex
02-11-15 01:38 PM
Quick Reply: How do i turn off airbag
