Check Headlight System after Air Instillation
Hi,
I had an airlift air system installed yesterday and it works great! But the problem is my headlights, I have a dash warning "Check Headlight System."
I believe this is because the new max height of my car, is no longer similar to stock height. I believe it uses a physical bar to maintain the self leveling correct? Is there a way Lexus can re-calibrate it, to know it's new max height, or trick it?
I would check to make sure the sensors are lined up as they should be. If they aren't, adjust them so they are, then see if that fixes your aiming issue (https://www.clublexus.com/forums/sus...ml#post3063720 and https://www.clublexus.com/forums/sus...ml#post2306282). If they are lined up, look through the this thread (https://www.clublexus.com/forums/is-...t-success.html) on how to manually aim them.
