Question regarding transmission and warranty
Hey guys,
I recently purchased a 2013 is250 from a used dealership.
1. I'm at 43k miles, is the car still covered under the 50k Lexus warranty even though I did not buy it from a Lexus dealer?
2. When my car changes gears the car will sort of hop to the 2nd gear, It's like as if I'm punching the gas pedal, Is this a problem?
When it shifts to 3rd 4th and 5th I can feel the car changing gears a little but it's not as bad.
Thanks!
Thanks!
Do you know the history of the car when you bought it?
You are covered with the 4 years, 50K miles, suggest you take your car to the dealer. Regardless where you bought it.
Describe the issue, they will road test it and let you know what needs to be done. Hopefully no other shop other than Lexus touched the car to void the warranty.
Good luck.
Good luck.
That's the best way to put it, it's an intense shift, the car jerks and maybe because I've been paying attention to it so much I'm just over reacting.
Yes it was owned by an older gentlemen. It was serviced on time has a clean title.
I think I'll take it to the dealership then and have them look at it.
Thanks!!
Thanks!!
Islandlex1
04-01-14 02:28 PM
coleco
ES - 5th Gen (2007-2012)
10-26-08 06:39 AM
