Low Oil Light Question
Old 10-21-15, 03:49 PM
Smitslex
Smitslex's Avatar
Default Low Oil Light Question
I have an 08 IS250 AWD, This is the 2nd time my oil light has came on since i owned it since last year. The first time the oil was little below the minimum mark and it did the same thing tonight. Is this a common issue for the 2.5? I don't see any leaks that i am aware of.
Old 10-21-15, 07:43 PM
Bichon
Super Moderator
Bichon's Avatar
You ought to be checking your oil level more frequently; I wouldn't wait for the low oil light to come on.
Cars can lose oil both through leaks and by burning it. How many miles has it been taking to consume a quart of oil?
Old 10-21-15, 07:50 PM
Smitslex
Smitslex's Avatar
I put a quart in it 2 months ago, it needs a oil change i know that also. Can the car needing an oil change cause it to lose oil? It just started this a few months ago light has came on 2 times in the past 4 months.
Old 10-21-15, 10:22 PM
pauls927
pauls927's Avatar
Can the car needing an oil change cause it to lose oil? It just started this a few months ago light has came on 2 times in the past 4 months..........Not usually.
Did you fill it back to the full level or did you just add a quart? Also, how many miles are on this engine? does blue smoke come from you exhaust? If the previous owner did not change the oil regularly or if its a high mileage motor, it may consume more than motor in good condition.
I would start with an oil change and monitor the oil burned approx every 1K miles. I would think around 1/3 quart every 5K miles is normal for an older motor.
Old 10-23-15, 03:22 PM
jay350
jay350's Avatar
Did u at least check the under of the car see if there's any leak?
jmacom1
08-13-15 09:38 AM
CheddaBob
03-24-14 03:18 PM
carlosL250
04-06-12 11:17 AM
sleets88
06-16-11 01:01 AM
JackV
09-30-09 08:20 AM
Quick Reply: Low Oil Light Question
