my2007 is250 change 2011 led headlight installation how to ?
Old 11-05-15, 07:06 AM
kenny5588
kenny5588's Avatar
Smile my2007 is250 change 2011 led headlight installation how to ?
:uh help ME~!!
Old 11-05-15, 07:23 AM
DRivera250
DRivera250's Avatar
https://www.clublexus.com/forums/is-...on-how-to.html
Old 11-05-15, 07:29 AM
kenny5588
kenny5588's Avatar
why installation 2011 led headlight no led ??? how to Enable led?
Old 11-06-15, 12:37 AM
kenny5588
kenny5588's Avatar
Default This Ok? 07 change 2011 led hight
Old 11-06-15, 01:56 AM
jay350
jay350's Avatar
It's really easy there's 3 wires for the leds they r located by one of the corner of plug they r red, green and black if I remember correctly one is 100% brightness one is 50% brightness and one is ground. Ground it and decide which brightness u wanna go with 50 or 100 then tap that wire to ig2 fuse under the hood and ur good to go. Tapping it directly to fuse so led will come on as soon as u turn the ignition to on. Other than those 3 wires everything else is plug and play. U do will lose ur afs so make sure u pull the fuse or it will keep blanking on ur dash.
Old 11-06-15, 02:05 AM
jay350
jay350's Avatar
And u don't have to cut any wire u can just remove the wire from the plug housing
Old 11-06-15, 04:39 AM
kenny5588
kenny5588's Avatar
Default What color is ground ?
Old 11-10-15, 05:16 PM
jay350
jay350's Avatar
black = 50% bright, green= 100% bright and red=ground if I remember correctly just test it with ur battery
jeffe005
10-11-17 04:19 PM
rohanstar
02-17-15 02:02 PM
ewcg0100
08-23-13 02:25 PM
silvaIS
09-29-11 02:36 PM
Quick Reply: my2007 is250 change 2011 led headlight installation how to ?
