Trans Problem
Old 11-08-15, 08:55 AM
LowIS619
LowIS619's Avatar
Default Trans Problem
Hey Guys,
I have a 2008 IS250 RWD. It has 140K miles. Runs great. Here is my problem.
If I'm driving down the freeway in between 75-79 mph and I get on the gas to pass someone on the freeway it will down shift but it delays, the rpms go up to 5000 and then it will violently slam into gear making the tires chirp. If I get out of the gas so the rpms dont go up so high it still slams into gear its just not as harsh. Lexus San Diego told me it needs a new transmission for the sum of $5000. I paid $12,000 for the car. YES I've tried to reset the ECU and Lexus San Diego check the ECU for and updates. Does anyone have any idea how to stop this problem. Thanks in advance for the help.
Old 11-08-15, 12:33 PM
Othic
Othic's Avatar
Originally Posted by LowIS619
Lexus San Diego told me it needs a new transmission..... Does anyone have any idea how to stop this problem.
Looks like you've already been told how to stop this problem.
Old 11-08-15, 12:46 PM
LowIS619
LowIS619's Avatar
I don't believe that is the solution. I've read that the GS has had the same issue and it was the TPS sensor. So asking if anyone else has had this problem. But thanks for the smart *** reply. 👎🏽
Old 11-08-15, 04:19 PM
Othic
Othic's Avatar
You provided absolutely no information. Is there a DTC that the trans set? How exactly did you try to reset the ECU? It sounds like you don't want the solution to cost your $5k. I have a free solution, just push the car wherever you need to go. I'm only a Lexus master tech, so what the hell do I know...
Old 11-08-15, 05:15 PM
LowIS619
LowIS619's Avatar
What's a DTC? I unhooked the battery.
How have I provided no information? I stated exactly what the car does and at what mph.
Old 11-08-15, 05:21 PM
LowIS619
LowIS619's Avatar
[QUOTE=Othic;9245751]You provided absolutely no information. Is there a DTC that the trans set? How exactly did you try to reset the ECU? It sounds like you don't want the solution to cost your $5k. I have a free solution, just push the car wherever you need to go. I'm only a Lexus master tech, so what the hell do I know...[/T
Thanks for the help
Old 11-08-15, 06:05 PM
LowIS619
LowIS619's Avatar
Codes? No there are no codes or has it ever thrown a check engine light.
Old 11-08-15, 07:54 PM
MWIS350
MWIS350's Avatar
Have you try to flush oil transmission at dealer? Most likely transmission solenoid problem. There are post about this issue in CL.
Old 11-08-15, 08:17 PM
LowIS619
LowIS619's Avatar
No I haven't.
Old 11-09-15, 01:39 PM
Gville350
Gville350's Avatar
Did the dealership actually reflash the trans ecu? Another member recently found out there was an updated flash available for our transmission. It seemed to have fix his issue for the time being. Definitely cheaper than a new or used trans. Worth a shot.
Old 11-09-15, 01:46 PM
LowIS619
LowIS619's Avatar
That's a good question. I'll make an appointment with Lexus to have that done.
Old 11-09-15, 02:54 PM
MWIS350
MWIS350's Avatar
Yes Lexus dealer updated my IS350 transmission ECU because I have code P0761 and P0894. One awhile it stuck on 3rd gear and sometime slipping.
Been couple of week and I have change 2 quart of transmission oil from the pan and so far so good. No code. They only charge me $65 for diagnostics.
Old 11-09-15, 02:58 PM
MWIS350
MWIS350's Avatar
Old 11-24-15, 07:06 PM
navarachi
navarachi's Avatar
awesome, how is it driving now? smooth?
Old 11-24-15, 11:18 PM
MWIS350
MWIS350's Avatar
The same I think, but at least no check engine light and code. Will see how long it will last.
Quick Reply: Trans Problem
