Do we need relays on HID fogs?
My HID fogs are going bad and mite just get a new conversion kit. I got a no name brand from modexpress years ago and i don't think it had a relay. Is the relay necessary?
Relays are used to enable a low amperage circuit to switch on or off a higher amperage circuit, like turning on your headlights.* If you are connecting your foglight to the foglight circuit/switch you might exceed the amperage rating of the switch, melt wires, and risk an electrical fire.
You should be OK if the HID setup doesn't draw a lot of current during startup. However, why risk it if the relays are so cheap.
