I was going up my friends driveway, not realizing i was going up a curb, i heard my bumper scratching against the pavement and i reversed immedatly, when i checked my bumper to look at the damage, the front right side of is totally damaged and i noticed the hinge holding the bumper was split.
Any suggestions?
Yes i know i should have checked before i went up, but these accidents happen.
Bumper tab is still intact. Are you sure you even had a bolt/nut attached to the bumper tab holding the bumper against the fender? Push the bumper back against the car and find a bolt/nut to attach the bumper tab back to the fender. Done!
I know the feeling! Was worse for mine cause I have a lip and lowered. It seems to be common in these cars. I got a new bumper cover cause all my tabs broke. My driveway is no joke for lowered cars. If the tabs are all ripped then new cover is recommended, unless someone has a good solution? I've heard about relocating the tabs but if they're all broken I believe a new cover might be the only fix?
how damaged is it? you might be able to drill a screw through it and connect your bumper that way. a lot of people shave their bumper tab down to make clearance for their wheels so if there is a good portion of the half left, you should be able to still use it!
