Check system light
Check system light
hello gentlemen,
I've been having this light quit often , it goes on an off, i would like to know what is causing that and how can i fix it or how can i eraser it.
thanks and have a wonderful weekend.
Super Moderator
Sorry, but allstar319 has this one wrong on two counts. Low air pressure gives the message "LOW TIRE", not "CHECK SYSTEM". Also, the spare tire does NOT have a TPMS sensor.
Reasons for the "CHECK SYSTEM" light going on-and-off randomly:
1. You have two sets of wheels, one with TPMS sensors in the garage, and one without TPMS sensors on the car. (Light turns off when the car is parked close enough to the stored set of wheels with the sensors for the car to read them)
2. You have two sets of wheels, both with TPMS sensors, one set in the garage, and one set on the car. The sensors on the car are either not programmed to the car, or you have the wrong set of sensors selected. The light turns off when you are parked close to the stored set of wheels with the valid sensors.
3. The battery in one or more of your TPMS sensors is getting weak.
Although, as I did suggest above, having the codes scanned would pin down exactly what is wrong with the TPMS system. Bring it to any tire place.
EyeKutr
06-12-19 10:45 AM
ByoungWoo
08-27-08 03:09 PM
