Bent outter lip on rim. Easy repair?
Old 12-08-15, 10:50 AM
Deathrow23
Deathrow23's Avatar
Default Bent outter lip on rim. Easy repair?
Bent just a little of my lip. Not concerned about the rash, that's easy.
Could I just heat up the lip with heat gun and use wood block with rubber mallet to bang out?
Wouldn't really care too much if it wasn't work wheels. Lol
Any advice, thanks.
Old 12-08-15, 11:15 AM
dyongg
dyongg's Avatar
Any advice, thanks.
not sure if you want to bang it out with a rubber mallet and heat gun; doesn't sound like it can end well for your wheels. I would get them professionally repaired
Old 12-08-15, 12:20 PM
Deathrow23
Deathrow23's Avatar
Took it down to wheel repair shop. Quoted $125.
Old 12-08-15, 01:51 PM
Byprodrive
Byprodrive's Avatar
Yes you can, I think you want to start on 1 side of the biggest bend below the 3. Go easy & increase force slowly if you need to. Try to visualize the bend happening in slow motion & try to reverse that sequence with your hammering. Try to make the rim contact the tire evenly. Once you get there remove tire & sand away the rough edge.
Old 12-08-15, 06:52 PM
srt1
srt1's Avatar
Why not get a new lip? But if you want something temp yes you can do yourself.
Old 12-09-15, 06:15 AM
cruzinZ
cruzinZ's Avatar
Aluminum does wonders with heat. But it will also have negative consequences in regards to strength.
My vote is for a professionally repair job. If your too cheap to have it done you're taking a chance on your safety.
Old 12-09-15, 06:38 AM
Deathrow23
Deathrow23's Avatar
Getting it repaired today. Also, need new tires. Price of having to camber your wheels i guess. sucks, these only had about 6k miles.
could it also be toe that is messed up?
Old 12-09-15, 07:57 AM
cruzinZ
cruzinZ's Avatar
Have it aligned as soon as possible & set back to factory specs. Any suspension modification that deviate away from the proper alignment will prematurely wear out your tires. Just think of this as a little lesson. (One that is going to cost you $$$). It could be worse. You could have had a blow out mid corner and wrecked/totaled your car.
Old 12-09-15, 08:12 AM
dyongg
dyongg's Avatar
yes get an alignment as soon as possible! your toe has a lot of impact on the life of your tires!
Old 12-09-15, 08:23 AM
metaleckz
metaleckz's Avatar
Also flip them
Old 12-09-15, 09:50 AM
Deathrow23
Deathrow23's Avatar
Yeah I thought about just flipping it, but won't take the chance on this one. For the next set, I will
Old 12-09-15, 11:32 AM
Deathrow23
Deathrow23's Avatar
Just got it back. Pretty good job. Polishing could be a little better, but I can finish that off. Other than that, I can't tell where the bend was at.
Old 12-09-15, 12:01 PM
dyongg
dyongg's Avatar
looks a lot better like brand new
Old 12-09-15, 02:05 PM
600rr05
600rr05's Avatar
^^^ agree looks good
Old 12-09-15, 02:31 PM
Deathrow23
Deathrow23's Avatar
Only thing I don't like is that the repair area doesn't have the oem coating protection now. Turns black when I use polish, but the other areas don't. Which will oxidize faster
416tt
01-31-14 08:35 AM
Karlson
Automotive Care & Detailing
14
08-30-10 04:41 PM
whise
04-12-10 10:21 PM
HotBlue400
Wheels, Tires & Brakes Forum
71
08-01-04 08:21 PM
Quick Reply: Bent outter lip on rim. Easy repair?
