eBay VIPMotoz LED Headlights
#151
I had the same issue with mine last year. I called VIP and they sent me another resister and all I paid was for the shipping. They were really cool about it. I changed it but I still have some trouble with it from time to time. I think it’s more of a wire issue than the resister at this point.
See5 (08-11-18)
#152
I inspected the resister and bulb using a multi meter and all seem to be working. The resister was 8 ohm for reference. I just unplugged the connection between resister and bulb, and then plugged them back. Now working again!
Regards
#153
Problem came back just after two days. This is annoying now. I don't get it on what is causing it. The wires were buckled up tightly. No turn signal on the front now.
#154
I have an 08 ISF and I'm looking to switch to these. Are a number of people experiencing issues with turn signals still? Also I read that my factory HID ballast won't work with these lights. How do I get the option of having an HID pre installed? Thanks in advance. Still new to the forums as I got my F a couple of months ago.
#155
i have a set of the vip motoz headlights for free if anyone wants them. Everything works and they have been modified to run the LED strip as the DRL. You just need to the run the power wire to an ignition source. Only problem with them is that both sets have condensation issues. I prefer not to ship these. Pick up in San Jose, CA
#157
Quick question before I put my car together. There's an extra plug that comes with the headlights. So far everything works with out it. See pics below. I'm also running some H1 LEDs as DRLs from iJdmtoy.com so far so good. I did splice in my decoder from them also from previous headlights. Module was modified before. So even if you buy one with the original housing it should fit in nicely. There's a lot of room inside.
Last nice cutoff once you remove the front bracket inside the projector. You can view the write up by whitebeast. It's on page 7 - 8 where he describes how to remove it.
https://www.clublexus.com/forums/is-...w-version.html
Still needs proper headlight aiming. I suggest proper aiming before you finally put the headlights in place. There is no room to make adjustments after you install. You can see diagram pic I found online. It's pretty standard for projector headlights proper aim.
Found this link after some extensive search on CL!
I found that the OP had also measured 54.00" center to center of the headlights. Which in turn is the same measurement that I got. EDIT for the spacing I'd leave it as they come. Once you go past 50" they have a gap. So I'd leave it, and just focus on up, and down aim.
https://www.clublexus.com/forums/is-...djustment.html
Edit: 4/13/21
If you notice no hot spot on your headlights.
Make sure your halogen/HID. That it's resting on the lower notch referenced below. If it's not you will get a weak light output. There is a lot of play in these projector locking tab. Being at the top will make the light spread bleed over the cut off plate.
I found out after replacing a burnt out turn signal bulb. I'd recommend 1156 bulbs as the description of PY21W is wrong. Get a better brand than what comes with the headlights. Replace at the time of instalation.
Make sure bulb metal base rests on tab circled in yellow.
Edit: 4/13/21
ShowGSLuVv
05-14-02 04:34 PM
