IS350 Engine "Fluttering" Noise - What would cause this?
Old 01-11-16, 08:43 AM
  #31
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
To be fair, the 2GR-FE is way more common and much cheaper than the 2GR-FSE, so I don't know if it would be quite as cheap to get a rebuilt unit, but who knows. Depends on what's available in your area.
Jeff
Old 01-11-16, 09:11 AM
  #32
ColdFusion
ColdFusion's Avatar
I'm currently shopping around, most of the engines I see are over 100k and hover around $2.5k-3k. I found a gem in Florida though at 77k for $2.9k, but I don't think I'll make a move until I get a final diagnosis.
Old 01-11-16, 09:27 AM
  #33
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Are they going to disassemble for an inspection?
Jeff
Old 01-11-16, 12:10 PM
  #34
ColdFusion
ColdFusion's Avatar
Jeff
I think so - I should probably call the dealer now lol.
Just noticed, since you're the one who did the 2GR swap, if you don't mind me asking, how much did you get your engine for?
Old 01-15-16, 11:59 AM
  #35
ColdFusion
ColdFusion's Avatar
So the car is at an independent garage now sitting for diagnosis; the owner tells me it's most likely the rod bearings, so he will take off the oil pan and lower part of the block to fully see the extent of the problem. If the crankshaft isn't damaged, all 12 rod bearings will be changed.
Fingers crossed the crank is OK
Old 01-18-16, 02:51 PM
  #36
ColdFusion
ColdFusion's Avatar
Default IS350 Engine "Fluttering" Noise (Update: Spun Rod Bearings)
Update: visit to the garage!
This the first time I've ever had one of my cars up on a lift. I wish I had one at home
Belly of the beast. The bottom of the block was completely taken apart to inspect the crankshaft and bearings.
Beautiful in it's own way. I noticed on the first picture I'm essentially one O-ring "shaft" away from a **** and *****...oh Toyota you.
The damage. Confirmed worn/spun rod bearings.
8 out of 12 bearing halves were all like this. Garage owner said there's no way this could've happened unless oil maintenance was skipped/not properly done. I would like to give benefit of the doubt to the first owner, but at this point I realize he knew of this condition before selling the vehicle.
Remnants in the oil pan.
At this point, all 6 rod bearings and 4 main bearings are going to be replaced. There is surprisingly no severe crank damage (I did not see connecting rod area damage, but the main bearing locations showed no damage whatsoever). Both bottom engine mounts will also be replaced, since the car is already apart and both are worn out.
Old 01-18-16, 03:20 PM
  #37
Zmon
Zmon's Avatar
Ouch. Did he give you an idea of what that's all going to run you?
Old 01-18-16, 03:23 PM
  #38
ColdFusion
ColdFusion's Avatar
Right now looking at around $1.5-2k.
Old 01-18-16, 03:32 PM
  #39
MWIS350
MWIS350's Avatar
Thank for updated.
Old 01-18-16, 03:38 PM
  #40
ColdFusion
ColdFusion's Avatar
At this point, we think the following series of events occurred that led to this point:
1. At one point, the first owner didn't do a proper scheduled oil change, or the garage where he did it didn't do it properly. Lubrication to the crank bearings became insufficient.
2. At time of purchase of the car, we noticed the car decelerated itself while cruising down from ~20mph. When no brakes were applied, it actually felt like someone was lightly tapping the brake, even though there was no driver input on the brake pedal. When the car was bought we honestly didn't think anything too much about this issue.
3. We now suspect that this "self-braking" phenomenon was actually the engine RPM trying to overcome a "stuck" rod bearing; at high RPM's the crank rotation would have no problem overcoming a loose rod bearing, but a low RPM's the rotations needed to overcome the resistance displayed as the "self-braking" symptom.
4. The noise starts when the rod bearing is free. At this point the damage has started, and was evidenced by the metal flakes in the oil filter.
The lesson in all this, at least for me? Do a goddamn independent mechanic inspection of any used car you buy. Should we have known about the possible cause of the problem we would've walked far away and looked elsewhere.
Expensive lesson learned.
Old 01-19-16, 05:52 PM
  #41
Gville350
Gville350's Avatar
First thing I do on ALL used vehicle purchases is actually remove the oil filler cap and smell inside the valve cover. Any smell of burnt oil or burnt metal and I run. Another trick is to convince the seller to have the oil filter removed and inspected for metal shavings.
So what will the shop do to ensure all of the shavings are out of the motor? Are they going to have the entire motor removed and cleaned and re-assembled? Do they feel that a micropolish of the journals will get it back in ship-shape?
Old 01-26-16, 10:05 AM
  #42
KIS350
KIS350's Avatar
Truly sorry to hear that. Even worse that you haven't even been able to experience the IS350 at its best. I hope you can find a cost effective solution man. I really feel bad for you. Everyones worst nightmare. Thanks for the pics and the update!
Keith
Old 01-26-16, 11:01 AM
  #43
isfdude
isfdude's Avatar
Hopefully everything will get repaired and you will love the amount of power you will get from a 6 CYL that pulls like an 8 CYL.
Old 01-27-16, 01:49 PM
  #44
ColdFusion
ColdFusion's Avatar
Right now the car's still on a lift....the garage has been having problems getting the correct rod and main bearings (Lexus is asking for some kind of engine block number in order to match the bearing). So right now it's just a waiting game until the parts come.
Old 01-28-16, 12:18 AM
  #45
isfdude
isfdude's Avatar
Originally Posted by MWIS350
Maybe will be better just to get new engine or install IS-F engine of possible.
It would be cheaper to just buy the ISF than do all the work as everything from the compiling era to the rear end is different. Even the whole nose is different. The ISF nose is 3 inches longer.
Quick Reply: IS350 Engine "Fluttering" Noise - What would cause this?
