IS350 Engine "Fluttering" Noise - What would cause this?
Old 03-07-23, 06:25 PM
  #61
2013FSport
2013FSport's Avatar
Received 1,533 Likes on 1,276 Posts
Originally Posted by ColdFusion
Hi, more gas results in more sound. If it truly is bearings then the sound gets louder when acceleration is applied since the crankshaft is rotating faster.
BTW for an update, the car is now at 159k miles and has been performing wonderfully
Good to see you are still here and logged some miles!
JM2C so I'll add that IMO rod bearings although yes, they make the engine louder, it's upon deceleration that failed or lose rod bearings really knock. For example, if you do a pull in 3rd gear and decelerate in 3rd gear you will hear a severe knock when slowing. The same is true with static revs while in the parking lot. Quieter when reving, knocking when you let off.
I bought a used truck years ago that rattled bad when decelerating. I needed it to last 10k miles. I did something *****y and polished rod journals in place, droped the mains enough to slide new bearings in, checked it all with plastigauge and buttoned it up with a new high oil pump. It lived far beyond 10k. lol
nparthi
05-09-19 07:59 PM
danmm7
GX - 1st Gen (2003-2009)
13
08-12-17 06:29 PM
shinbo
02-23-17 06:45 PM
IS250TW
12-19-13 03:44 PM
cutecboy
12-19-01 02:02 AM
Quick Reply: IS350 Engine "Fluttering" Noise - What would cause this?
