Rough idle at stop
Old 12-29-15, 10:12 PM
Marcose250
Marcose250's Avatar
Default Rough idle at stop
I've noticed that my is250 rpm's shake when car is at a complete stop. Needle moves slightly non stop and makes car shake slighty. any ideas what it could be?
Thank you
Model 08 is250 85xxx miles
Old 12-29-15, 11:25 PM
Parsa
Parsa's Avatar
carbon build up issue probably, there is a 9 year, unlimited mile warranty at the dealer for this. it was a csp released some time ago, the dealer with do a top engine clean and replace piston rings i believe. call the service extension of your dealer and ask about it
Old 12-29-15, 11:34 PM
Marcose250
Marcose250's Avatar
I had the recall done to it like about a year ago on the carbon build up so im not sure if they'd still check up on that?
Old 12-30-15, 10:23 AM
Parsa
Parsa's Avatar
mine was done in 2013 as well, still a problem. the recall is just a band aid fix, the problem is due to our engines being solely direct injection so as long as you have that engine it will be a problem. they do replace piston rings and things which will slow it down but it still occurs. you should have top engine cleaning done. look up "direct injection carbon buildup" on google
Old 01-01-16, 03:21 AM
600rr05
600rr05's Avatar
i had the carbon build up done but still happened so they also replaced my pistons maybe take it back in and see if they can replace them.
Old 11-19-20, 01:13 PM
MatthewMM
MatthewMM's Avatar
This is a known issue and Lexus changed the engine design in 2013 to have have manifold injection when the car is cold.
"December 8, 2015 MANUFACTURER COMMUNICATION NUMBER: L-TT-0192-15
Components: ENGINE AND ENGINE COOLINGNHTSA ID Number: 10152274
Manufacturer Communication Number: L-TT-0192-15
Summary: TT: Some IS250 and GS300 vehicles may exhibit one or more of the following conditions:
? MIL ?ON? DTC P0300, P0301, P0302, P0303, P0304, P0305, and/or P0306.
? Intermittently runs rough after coming to a stop with the engine at operating temperature.
? Intermittently runs rough with engine misfires present after a cold soak startup.
NOTE: The recommendations in this document apply to an intermittent misfire concern. If a vehicle exhibits a steady misfire, the root cause is not related to the referenced service bulletins and the repair manual should be referenced for diagnosis."
https://www.nhtsa.gov/vehicle/2006/L...Communications
https://static.nhtsa.gov/odi/tsbs/20...52274-9999.pdf
My symptoms are also I get MIL, and VSC disabled lights. I used "OBDLink MX+ OBD2 Bluetooth Scanner for iPhone, Android, and Windows" (available on amazon) to pull codes and data logs: RPM, location Coolant temp...
I also forwarded the case to https://www.krinsklaw.com/contact and https://mccunewright.com/contact-us/ who have had class actions against Lexus and Toyota.
XhyDra
09-02-23 04:39 PM
LanceK
01-29-19 07:30 PM
chucktaylu
06-05-18 07:39 AM
meis250
Canada
49
08-17-16 02:55 PM
Paolo22
08-14-12 06:08 PM
Quick Reply: Rough idle at stop
