Change my Factory HID headlights to a Third Party Headlight Set [2007]
My HID bulbs have gone out and I want to instead of replacing the bulbs, change them to one of the third party headlights on the market (I want that led strip).
However, on the description of numerous headlights, it says it's not compatible with Models with Factory HID headlights, or it says to disable the AFS system. Has anyone with an 07 IS 250 gone through the same problem ? How would you go about disabling the AFS system or do you know of any third party headlights which ARE compatible with Models with Factory HID Headlights?
Thanks again for the help!
Losing the AFS was the main reason why I ended up not replacing the headlamps and just sticking to replacing the bulbs.
Hello, if you're like me and don't have 1200-1600 to spend on Oem 2011 headlights, then this would be a cheaper alternative.
I use it as well as forum member whitebeast.
https://www.clublexus.com/forums/is-...w-version.html
On a side note, I for one think AFS is really useless. Maybe it's just me. I don't really have a use for it so I had no problem disabling it
So is it still just plug and play? How do I got about disabling AFS?
Fitment is 95%, nbd. The halogen bulbs it comes with sucks. So just get a nice HID kit. Followed Whitebeast and mounted them under the headlight. It looks just like stock.wires are neatly tucked away and the ballast doesn't take up space.
Theres a fuse box under your steering wheel, refer to owners manual and pull the AFS fuse. ITs a red fuse thats 7.5 amps.
Good lucks! You can pm me if you have more questions.
Here's another alternative from what I can interpret it's a replacement for factory HID so your stock HID ballast and bulbs will work with possibly an AFS bypass
https://www.clublexus.com/forums/is-...eadlights.html
was def looking at that too, however My guess would be that its 800~1200.
Since OEM costs 1800~2200? from dealer at least.
Either way I am extremely happy with the eBay reps. The cut off line is much more clear than stock lens too.
Jeff Lange
02-23-12 09:43 AM
