Calling all techs!!!
Morning .The other morning the temp dropped, started my car it stayed on for maybe 10 secs and died. Hasn't started since ,if I try it'll crank maybe 3/4 of the way then nothing , It won't let you try again for sometime. 2006 lexus is250 6spd,f sport suspension and rims ,nothing else. Any help is appreciated!!!! thanks in advance.
I'll give you a bump here.
When you say "it'll crank maybe 3/4 of the way then nothing" do you mean that the engine rotates about 3/4 and then just stops? Or do you mean the engine cranks and fires off for a split second and then dies?
If it's a cranking issue have you checked out your battery wires and wires on your starter? If they are loose or severely corroded that will definitely cause starting issues.
Is the Check Engine Light on? Any other lights?
I'm still somewhat new with my Lexus but could it be an Anti-Theft/Alarm issue that's disabling it?
In the process of checking that ground now. No none.
aspeckt
07-08-12 11:31 PM
