I installed the f sport pedal set and thought about the lonely brake pedal sitting all there by itself and came up with this. It a clutch pedal cover. I had to make a plate that would receive the cover. I bolted that to the existing foot pedal taking off the rubber cover first.
There is a hole in it so used a 1/4 inch flat head screw. On the back end of the pedal I used a larger washer , then smaller one with a lock washer and nut. Since the surface of the pedal is convex the flat plate wants to rotate. I solved that with inserting a star washer between the plate and the existing pedal. Pedal cover took a bit of work to put on the plate.
