Is350 injectors in the is250 engine
I am not sure if this has been before, but i previously had some problems with my is250 injectors
being damaged and needed a replacement asap. With the only quick solution being to put in 4 is350 injectors and leave the 2 of the is250 injectors in, as i only had 4 replacements, The car
started but sometimes i get misfire on cylinder one and randon misfire codes on the scan tool.
Has anyone used a full set of is350 injectors on their 4gr with success?
First thought was...WTF? Then thought, hmmmm...just maybe they flow the same amount of fuel into both motors. Doubtful, but possible i guess...even with didn't part numbers.
So I assume these IS350 direct injectors are a direct plug-and-play into the existing IS250 harness?
Anyone know the flow rates (CC) between the two direct injectors?
GreyDemon
05-17-06 07:52 PM
