Motor Oil Question
Motor Oil Question
I run My 350 hard and I seem to burn oil. I am using the generic stuff from the dealership. I was told if I use some better oil (RL,RP) I might not burn as much. What oil do you guys run in your 350? If it is Redline or Royal Purple do you like it and where do you buy it?
Are use mobile one or Pennzoil ultra synthetic oil. I beat on my cars all the time and race everything. These 2 oils hold up really good. I made videos of cars I scrapped I removed the antifreeze and ran the engines with different oil brands to see which ones will hold up. Also it's normal for the isx50 to burn a little bit of oil as the pcv system is made to lube the upper valve system. I found that out when I worked for Lexus.
bb700092
01-07-19 06:54 AM
