Audio system doesn't have any sound
Old 02-07-16, 05:17 PM
Babak
Babak's Avatar
Default Audio system doesn't have any sound
Hi guys,
my Lexus IS250 2007 audio system has a problem. when i turn my audio system on, sub woofer make a sound like knocking and after that no sound.
I tried radio and aux and they are the same, no sound.
what do you think the problem is?
I tried to unplug the woofer and it didn't work again.
Old 02-07-16, 06:22 PM
Bichon
Super Moderator
Bichon's Avatar
Do you have the Mark Levinson system? I'm thinking it might be a bad amp.
Old 02-07-16, 08:19 PM
Tro209
Tro209's Avatar
Yeah sounds like a bad amp like Bichon mentioned however I'm not very experienced in this area.
Hmmm.. Maybe it's just your cars way of saying that it's time to upgrade the factory stereo system ?
Wait you mean all your speakers don't work or just the subwoofer?? Because mine blew out about a year ago and haven't bothered replacing it yet . It's a common problem on Mark Levinson equipped models.
Old 02-07-16, 09:01 PM
Babak
Babak's Avatar
How can i realize what is my audio system? I kust bought the car and it doesn't have owners manual.
And the problem is when i turn on my audio system,my sub woofer just make a sound like doooop. And after that nothing. I tried radio and aux input. Non of them works.
You think i should replace my amp? Do you have any idea how much is need to pay to replace that?
Old 02-07-16, 09:03 PM
Tro209
Tro209's Avatar
What I meant to say is, does your car stereo play any music at all? Or is it just the subwoofer not working?
Old 02-07-16, 09:59 PM
Babak
Babak's Avatar
No it does not play anything.
I mean Audio system shows it is playing in audio system display, but there is no sound.
Old 02-07-16, 10:25 PM
Tro209
Tro209's Avatar
In that case that is not a common problem. Maybe you should have a Lexus tech take a look at it. It could be the amp but then again it could be anything really. Sorry if I'm not of much help. Good luck
Old 02-07-16, 10:27 PM
Babak
Babak's Avatar
Do you have any idea that how much amp can cost?
Old 02-07-16, 10:30 PM
Tro209
Tro209's Avatar
I can't say honestly since it hasn't happened to me nor have I heard of this issue personally. Maybe some one else can chime in on this with more experience than myself. This is why I said you should probably call up Lexus, set up an appointment and have someone knowledgeable look at it. That way you'll know exactly what you need and they can give you a price quote for parts and labor. If it's too much, I'm sure you can alternatively take it to a reputable stereo shop and they can replace what needs to be replace with something of higher quality .
Old 02-08-16, 07:46 AM
Icy350
Icy350's Avatar
If you just bought the car, most dealerships even 3rd party have a 30day warranty incase anything goes wrong.
Check with them and see if they will remedy your issue.
Old 02-08-16, 08:29 AM
Babak
Babak's Avatar
I bought the car as is. It doesn't have any warranty
Old 02-08-16, 08:33 AM
Icy350
Icy350's Avatar
Like auction or Private seller?
oh man that blows
Sorry I cant really offer any more help, Audio is not my field.
Old 02-08-16, 06:49 PM
Gville350
Gville350's Avatar
I'd visit a local stereo shop and have them test the factory amp. To me, it sounds like its in permanent "protection mode." But before you do this, check that the amp is actually in trunk...passenger's side. Remove the black plastic piece and you should see it right there. Then check that it has all of the connections tightly connected to the amp.
Good luck!
Old 02-08-16, 08:25 PM
Babak
Babak's Avatar
thanks Gville, Can you explain a little more about where i should check for amp. in the passenger door you mean?
Old 02-09-16, 12:17 PM
Gville350
Gville350's Avatar
^No. It's in the trunk. Open trunk, remove the black plastic piece on the passenger side of the trunk floor, and the amp is below it.
Quick Reply: Audio system doesn't have any sound
