so haven't been able to find a for sure answer. Is there camber plates for bc racing coils on the awd platform? or and cheap router for from camber adjustment? most of them I have found are almost $300 like the megan racing uca.
Camber plates work with a strut suspension. ISX50s don't have struts, so a cheap, (or expensive for that matter) camber plate won't work. In order to adjust camber you have to move the pivot points of the A arms, and your only options are the adjustable ball joints shown above, or a complete upper arm replacement, AKA Megan Racing or similar.
will do might be lifting her up a bit. tired of using wood to get in and out of the driveway. and tired of scraping the exhaust, don't want a hole. gonna take a quick peak first to see if I can do some bending and pull the exhaust up first
