Navi & TPMS Questions
Is there a way to turn off the Navi screen when I do not need to use it for anything?
Also, what aftermarket TPMS sensors are people using with good success? I need to replace two of mine.
If you do not need the map but do not want to waste the whole
display, go into settings and turn off "Auto Screen Change" This
will allow the Audio screen to stay on and provide entertainment
information.
The moment you encounter a traffic backup and would like to know
if the side street is a dead end or connects just tap the Map Button
information.
To answer a question that you didn't ask, but came to mind while I tried to ponder why you would object to having the map displayed at all times: make sure that you don't have your instrument panel lighting set at full brightness, or the nav screen won't go into night mode, making it annoyingly bright after dark.
