What is this noise??
#62
But was your squealing constant or sometimes under specific circumstance? Mine only does it sometimes (no telling when it will do it). And only at slow speed (5-10 mph) with my foot OFF the brake. It sounds like a rotating squeal like it squeals in tune with the motion of the front wheel rolling at slow speed.
Also it only happens sometimes. There times where the car is as quiet as Lexus intended it to be. (Minus my exhaust lol)
What tipped me off was I noticed a line about a quarter inch wide appearing on the rotor.
#64
The squealing was pretty much constant, but how loud it was varied. The loudness would change after making a stop. I would have the noise while I was rolling along; using the brakes either stopped or greatly diminished the squealing. Sometimes making a turn affected how loud the squeal was. But I had the noise at all speeds, although I don't think I went over 40 mph while I was trying to figure it out.
So if these pads didnt originally make noise to begin with, and replacing them didnt solve my problem, I doubt the pads or shims (or whatever theyre called) are the culprit
#66
Maybe I'm wrong, but I'm getting the impression that you haven't looked at or checked theses guides/shims. It is relatively easy to look and check those guides/shims to see if they are touching the rotor. The area where it straddles the rotor should have a good 2-3 mm clearance.
If you are using Lexus parts, then I doubt that these pieces are the problem. But if they came with aftermarket brake pads, the possibility exists. FWIW, I used Wagner brand.
#67
Another Update
So today I finally got a video to show you guys again what im dealing with. I also took the opportunity to see how else I can make the sound happen. So get this..
I drive under 20 mph I can hear it but the sound starts to disappear as the speed increases. If I even lightly press the brake the sound goes away till I let go of it. Now heres something new I discovered. When I turn the wheel left or right I can hear the sound just a tad bit more
Im wondering what this might mean? In the video I will post shortly, you will hear the sound I am talking about. The video has my camera looking at the driver wheel as I drive so that you can get a better feel for the sound. And yes it is coming more loudly from the driver side but not so much the passenger side.
In the video the sound disappears everytime I hit the brake even slightly. And as the wheel turns, you can hear the sound a bit more. I hope this helps solve this problem once and for all. Thanks guys
Not sure why the video quality looks choppy. On my phone its crystal clear and smooth. Sorry about that guys but you get the point anyway.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#68
The video plays fine for me. Not choppy at all.
If the squeaking goes away when you apply the brakes, it has to be coming from something placed under tension when the brakes are applied. Have you checked out the ball joints?
#70
Yes, the problem lied in the rotors. After changing them out the noise went away and for safe measure I bought another pair of brake pads again and replaced them as well. The main problem was the rotors though. I had another mechanic look at it and he said they were worn. And sure enough replacing them was all I needed to do. Super glad it was an easy fix...
HOWEVER, as of recent weeks the brakes are starting to make that squeal again.. My mechanic buddy told me it's because the rotors I bought were a cheaper brand so that may explain why. Next time I change them I will he going OEM. No more auto zone/ O Reilly rotors for me.
#72
I also remember reading up on this issue on an Acura Integra forum somewhere which is why I bothered to replace the rotors since some one on that forum had a similar problem... Do yours have this issue?
#73
Not sure to be honest. He just something along the lines of that you could tell the rotor needed replacement because of how it looked I guess. Wish I could be more helpful but I honestly don't really know why it caused the noise. All I know is that once I changed the rotors the problem went away.
