Aftermarket Wheels 18' Help
Hey, I fairly new and I had couple questions I just want to verify before i make a purchase. I have 07 IS 250, with the 18' wheels as 225 front and 255 back. So question is
- If i wanted to go like 235 front and 265 back with either 35/40 Width, would that work?
- As well as what rim size should i be looking that would fit my current stock size now, as well as fit the fatter tires I plan to get later down the road, i was thinking 8.5s but just wanted to make sure.
And if someone could maybe explain what offset to look for :3 i googled my car and said it recommends i get a high offset, but what is considered high? And what would you recommend, same offset for both front and back? I understand most of this is probably personal pref, but if i was going for nice casual look, what am i going for
Thanks!
Thanks!
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Welcome,, suggest you check out the FAQ sticky at the top of this forum
In it you'll find a link to a huge wheel fittment thread that answers your question
https://www.clublexus.com/forums/is-...tart-here.html
