Headlight bulb stuck to harness
Old 03-02-16, 06:10 PM
lexusben
lexusben's Avatar
Default Headlight bulb stuck to harness
Title says it all. I am trying to replace one of my headlights. I am at the point where the harness is exposed and you twist it off to expose the bulb. Unfortunately I twisted the harness to the unlock position and it is stuck to the bulb. I can neither take the harness off or get to the bulb. Any help is appreciated.
Old 03-02-16, 08:52 PM
Bichon
Super Moderator
Bichon's Avatar
Dumb question; are you sure you are turning it the right way?
Old 03-03-16, 07:16 AM
lexusben
lexusben's Avatar
I'm turning it clockwise so that it is horizontal. It is the driver side bulb. I think that is the right way, I seem to be able to feel it lock and unlock when I turn it this way. It just won't really unlock lol.
Old 03-03-16, 08:47 AM
Bichon
Super Moderator
Bichon's Avatar
Try turning it the other way. It has been a few months since I changed mine, but if I recall correctly you have to turn it counter-clockwise to remove it. I also remember that there is a diagram printed right on the face of the socket with an arrow and the word "lock" showing which way to turn it to lock it in place; obviously you would turn it the other direction to unlock and remove it.
Old 03-07-16, 09:31 AM
lexusben
lexusben's Avatar
Thanks for the advice, guys. It turned out to be the cold weather. The first time I attempted this it was around 30 degrees outside. I tried to get the bulb loose two days later when the temperature was in the 50's and the harness came off very easily.
Old 03-07-16, 09:39 AM
MikeFoxx
MikeFoxx's Avatar
Was gonna say warm it with a blow dryer but I see you got it worked out.
Old 03-07-16, 10:42 AM
Bichon
Super Moderator
Bichon's Avatar
So was I right, counter-clockwise rather than clockwise to remove?
Old 03-07-16, 12:37 PM
Gville350
Gville350's Avatar
I remember one of mine being difficult as well to remove. But just took patience and it finally loosened up.
durps
SC- 1st Gen (1992-2000)
04-29-12 05:24 PM
cowsgomoo
05-27-11 04:27 PM
lig
Maintenance
01-21-03 01:25 AM
933005spd
10-05-02 08:16 PM
messysc
Maintenance
03-31-02 10:07 AM
Quick Reply: Headlight bulb stuck to harness
