Dead Lexus IS250 Anyone can help???
What was the test method? You pulled all of the blade style ATC fuses? In the cabin too?
The bus bar fusable links would be best if done via test lamp that draws current.
Beyond fuses you likely have an open somewhere. Either ground, hot 12+, or some data link.
I'd pull the ECM as many have found compromised connections here.
Everything is dead, only response i am getting is the FOB locks and unlocks the doors, power seats work
No Acc or IGN from the push start button
security light flashes as normal
all fuses, including the ones under the clear cover have been checked, double checked, and triple checked.
Does the green push button led lights up?
Ok so if you sit in your car does your dash lights come on? does the green light comes on the push button? So it happened to me once i parked it and it wouldn't start. no lights on the dash battery was good just the green light on the button when you hit the brakes with key in the pocket. It was the fuel pressure sensor. Disconnect connect back if it fires up and shuts off then its your issue.
