Will these wheels fit my RWD IS250?
Hi,
Thinking of buying these wheels for my Lexus IS250 RWD. The bolt pattern matches, but I'm concerned about the size.
The tire states: 225/35/ZR20.
Will these fit??? Should I be concerned about tire rubbing or anything else, tips, etc??? Check the pic.
Thanks.
Thanks.
Thanks for the replies thus far.
@Zynthe
I was following this post: https://www.clublexus.com/forums/is-...-part-uno.html
Also, someone posted this (don't have the link) of their setup on an IS250:
Rims
Cordon Alloys CR-10 Matte Silver w/ matte black accents and chrome lip.
Tires
Vredestein Ultrac Sessanta
Front
20x8.5x30 Rim 245/30/20 Tire
Back
20x10x38 Rim 285/25/20 Tire
The aspect ratio is probably the concern here?
@Gville350
This is what it states for bolt pattern details on my vehicle:
2006 Lexus IS 250 (RWD)
Bolt Pattern (in): 5x4.50
Bolt Pattern (mm): 5x114.3 (confirmed for these wheels)
Offset Range (mm): 34 to 45
Front Center Bore (mm): 60.1
Rear Center Bore (mm): 60.1
Stud_Size: 12x1.5
@Zynthe
Rims
Tires
Front
Back
@Gville350
Stud_Size: 12x1.5
Okay, so I took the wheels to Lexus and got their opinion.
They fit great! - slight rub when turning the wheels completely, but they assured me it's nothing major.
It rubs against a plastic piece that I can easily snip off if it causes an issue, but they said I would wear out the plastic piece first before the rubber or any damage would occur to the vehicle.
I took some pics - take a look. Will mount these after I throw on some black cross drilled rotors, calipers, and replace my pads. Hopefully will post some better pictures once all completed.
Thanks for everyone's help!
