Does not shift above 3rd gear
Since it's Holly weekend, I haven't had a chance to take my car to see what code it does throw out there.
My car suddenly does not shift 3rd gear. Check light was on but I removed the negative cable from the battery to reset. Check light is gone, tested the car and it worked fine but issue persisted again.
ANY ideas what this issue can be? Am so worried. ..
Yesterday I tested and the car ran fine, taking in consideration that the check engine light remains on. I didn't not test it using "S" yesterday. But the day the issue started I did use the "S" mode and the car did not go higher than 3rd but you can see in the dash that numbers/shift move.
I still haven't had a chance to get any code sine shops are closed due to Holly weekend.
Is the CEL expensive and is there a way that the car can be removed from locked or limp mode when they connect it to the scanner?
Had a friend comen over and was able to scan. Code that showed up wad P2714. Is this an easy fix? What part needs to be purchased? The shop is 10 miles from home can I drive it to the shop?
