Inside tread wear, best tire for flipping?
IVe tried a few diff alignment specs with very little toe out and still get inside tread wear,I really like the conti dws tires i tried last,super quite and decent performance. but the tire has a outer and inner listing on the sidewall even though it is not a direction tread pattern,it is diff from outside to inside. Is there another tire with 5 tread wear that can be flipped? i run stagger setup also,need 285 and 235 20
Not sure if this tire is available in your sizes, but I'm really enjoying my Federal 595 EVO tires I've got up front. Don't let the lower treadwear fool you; these things are lasting just as long (if not longer) than my BFG KDWs that have a 300 treadwear rating. I flip my tires as well when needed; I've only be purchasing symmetrical tires because of this for years.
