Headlights low
https://www.clublexus.com/forums/sus...e-nf210-s.html
Oem I think. Bought the car second hand so im not really sure im going to adjust them tonight. And send you guys pictures again. From lastnights drive I noticed the light is doubleing there are two cutt offs.
Super Moderator
I was going to buy a m3 and only settle for this because of the milage. I have no clue what the previous owner had done to the lights.
On second note while doing some investigation I found out one of my hid high beams is burnt? or what ever that is.
Where can I buy some decently prices HID bulb?
Oh and how can I remove the shudder. I noticed that When my lights on against the wall If I run my finger down the light. It only starts blocking it at half way.
I'd still like to see a picture of your lights on a wall @ 25 feet. Any light colored wall will do.
If those are going to the lows, then someone put aftermarket HIDS in. I see two scenarios here, bulbs and/or ballasts are super old or complete junk and need to be changed, or, the cheap bulbs are putting out too much UV and damaging your projector bowls. IMO, I'd just put halogens back in there (size should be h11). That is if those ballasts are going to the lows. As for the high beam bulbs, those just look like regular halogen bulbs tinted yellow. I'd just throw any old Sylvania bulb in there and call it a day. Bulb size is 9005.
Ill get those pictures in literally a minute from the post you sent me earlier in the week at 25 feet.
And how about those shutters can they be removed? Or the ballast turned up somehow?
cheers
Can you get the drivers side adjusted upwards? It's really hard to see how that side is doing. Just take a picture of them on the wall after having them on for about 20 seconds, they should be fully warmed up by then.
That slight color flicker throws me off a bit, can you see where those ballasts you found lead to? I'd really like to know if they're going to your low beams or not.
Well I just royally ****ed up. I got the passenger side a littler higher... got driver side to match.. Screwed it one extra turn to call it good. then the whole thing dropped or seemed to have dropped. The passenger side perfect now the drivers side... points literally at the floor infront..
How do you fix it now...
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
I think my passenger beam is too high now.
Did you ever look to see if those ballasts you found go to your low beams or not?
