Headlights low
#31
See the white hotspot on those pictures? The passenger side is like a half oval under the cutoff, which is how it should be.... The driver side looks a tad bit off to me, like the hotspot is expanding the width of the beam. Maybe it's how the IS projectors are, I haven't really taken a look at mine.
Did you ever look to see if those ballasts you found go to your low beams or not?
There are four ballast two to the dogs and two to the low beam.
#32
from your latest picture looks like the driver side can go little higher and the passenger side can go down to line up to the driver side... which should line up like the picture below
#34
I don't know if I can adjust the driver side any higher because the lifter already popped out of the joint once.
I am going to lower the passenger side
And I can't aim the light left to right. I for some reason can't get the screw driver into that slot.
#35
Super Moderator
Well few problems I can't get that bulb put its impossible with the room left at the driver side. Would have to remove the whole bumper.
#36
tired of doing **** on this car.
