2008 IS250 engine noise
Old 04-16-16, 11:14 AM
test_accou
test_accou's Avatar
Default 2008 IS250 engine noise
Hello all,
I have a 2008 is250 63K miles. Recently the engine makes weird noise (cold or hot engine temperature, no different). The car performance seems to be normal. Engine oil level is normal, NO leaking coolant fluid. Please help identify what is making noise?
video attach below:
https://www.youtube.com/watch?v=d99y...ature=youtu.be
Thanks in advance!
Old 04-16-16, 12:09 PM
PAVGR
PAVGR's Avatar
Originally Posted by test_accou
Hello all,
video attach below:
Thanks in advance!
I think it's the water pump that needs to be replaced
Old 04-16-16, 12:25 PM
2GSKaizen
2GSKaizen's Avatar
I would also check the Harmonic Balancer/ Crank pulley. It def sounds like its something being driven on the serpentine belt/or possibly cam belt. Maybe a bad bearing on an idler puller?
Old 04-16-16, 12:35 PM
Zmon
Zmon's Avatar
+1 on the water pump. It def sounds like the bearing went bad.
Old 04-16-16, 02:20 PM
lexuspaaji
lexuspaaji's Avatar
yeah pretty sure its the water pump, I had the same noise
Old 04-16-16, 02:37 PM
test_accou
test_accou's Avatar
Thanks all for your suggestions, most pointed to the waterpump. I will order the waterpump and plan to DIY.
Old 04-16-16, 04:17 PM
g1itchgsr
g1itchgsr's Avatar
I would check the other easy to access bearings as well before you order the water pump. I thought my water pump was bad but my mechanic used the "screwdriver" method (google it) to ID that was idler pully bearing not my water pump.
Old 04-17-16, 03:56 AM
test_accou
test_accou's Avatar
Thanks, I will check!
Old 04-23-16, 07:07 AM
flektone
flektone's Avatar
Any update on this? Im getting that same growling noise but not that pinging. While its not leaking I was to told my water pump is going bad. The car has 77k and I know that its right about time to replace the pump.
Old 04-24-16, 02:34 AM
Toxicxk23
Toxicxk23's Avatar
110% water pump. Had the same exact issue before. Update us with your repair!
Old 04-24-16, 06:28 AM
flektone
flektone's Avatar
Should the car not be driven at if the water pump is failing and making this noise?
Old 04-24-16, 06:31 AM
Toxicxk23
Toxicxk23's Avatar
I would fix it as soon as possible. If the water pump completely fails and doesn't push coolant through you could end up really damaging your engine. Not a risk worth taking IMO.
Old 04-24-16, 06:34 AM
flektone
flektone's Avatar
ok thanks im taking the car in this week. I have another car to use to drive around town, i wont risk it.
Old 05-03-16, 10:33 AM
test_accou
test_accou's Avatar
Replace the water pump and everything back to normal. Thank all for your suggestions!
Old 05-03-16, 12:55 PM
Gville350
Gville350's Avatar
Glad you're all fixed up!
michelchar
ES - 5th Gen (2007-2012)
06-18-19 09:05 AM
adriann829
10-28-16 11:01 AM
adriann829
10-27-16 05:32 PM
moses0324
09-07-16 04:29 PM
Quick Reply: 2008 IS250 engine noise
